Horizontal slices of 3D objects
  • September 25, 2022
  • 67 views
markvv
Hi!
Is it possible to slice 3D objects at a specific height?
For example, I have a 3D model from a building, and I'd like to know what the exact outer bounds of the house are at +2m above ground level.
Thanks,
Mark
Best answer by daveatsafe
Hi @markvv​,
FME 2022 now supports surface clipping, so it is possible using the following method:
  • Create a 2D box well outside the 3D object to be sliced with a 2DBoxReplacer
  • Elevate the 2D box to your desired clipping elevation with a 3DForcer
  • Extrude the elevated box by a very small Z distance (ie. 1mm) with an Extruder
  • Use the resulting extrusion as a Clipper in the Clipper transformer
Screen Shot 2022-10-04 at 9.04.04 AM
daveatsafe
Forum|alt.badge.img+20
  • October 4, 2022
Hi @markvv​,
markvv
  • October 4, 2022
Hi @markvv​,
Thanks Dave,
Great, this works!
