Hi, I haven't used FME in quite a while due to the flu outbreak. I have FME 2017.1 and have found that it will no longer reach in to my SDE due to the Legacy deprecation from ESRI. Are there any transformers I can use in 2017 that I can use?
  • December 1, 2021
  • 5 views
hkingsbury
Forum|alt.badge.img+67
  • December 2, 2021
Here's the compatibility matrix between FME and Esri
https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
I'd suggest you upgrade to the latest release - 2021.2 - it brings in some massive improvements from 2017
