Hi, I am using a fmeserver engine image as a base image and trying to build a docker image with some more additional installations like azure file storage, oracle client etc. While I am trying to build the image, I am getting the following error.
  • Nov 28, 2022 6:56 AM UTC
  • 0 replies
  • 46 views
This is the error I am getting when I trying to upgrade the pip --version in the base image and build a new fmeserverengine image:
Step 2/45 : RUN python3 -m pip install --upgrade pip
---> Running in 95e4bf57b3f0
Fatal Python error: Py_Initialize: Unable to get the locale encoding
ModuleNotFoundError: No module named 'encodings'
Current thread 0x00007f43b515f740 (most recent call first):
Aborted (core dumped)
Service 'fmeserverengine' failed to build: The command '/bin/sh -c python3 -m pip install --upgrade pip' returned a non-zero code: 134
The base image which I took it from :
/quay.io/repository/safesoftware/fmeserver-engine:20632
