hi, i am new to fme desktop I have in a csv lines stored in a column like [[x,y],[x,y],[x,y],[x,y]] and i dont know how to transform into fme line geometry Please help
  • Jul 12, 2022 1:00 PM UTC
  • 83 views
danilo_fme
Forum|alt.badge.img+58
  • Jul 12, 2022 2:09 PM UTC
Hi @alain2002​
The transformer LineBuilder you can create a line.
First you need to geospatial your points - VertexCreator.
Thanks,
Danilo
geomancer
Forum|alt.badge.img+71
  • Jul 12, 2022 2:10 PM UTC
One solution is to turn the coordinate list into a WKT string (Well Known Text) using some RegEx in an AttributeManager, and feed the results to a GeometryReplacer.
WKT_RegEx
LINESTRING (@ReplaceRegEx(@ReplaceRegEx(@Value(CoordList),"(\d+),(\d+)",\1 \2),(\[|\]),""))
WKT polyline representation: LINESTRING (x y, x y, x y,x y)
@ReplaceRegEx(@Value(CoordList),"(\d+),(\d+)",\1 \2): replace a comma standing between two numbers with a space (a number may contain digits and a dot)
@ReplaceRegEx(......,(\[|\]),""): replace any [ or ] with nothing (both [ and ] need to be escaped with a \ because they are special chararters in regular expressions).
You may test regular expressions in the StringReplacer.
dustin
Forum|alt.badge.img+36
  • Jul 12, 2022 2:23 PM UTC
Several ways to accomplish this, but the attached workbench should work. This assumes the column name is 'coordinates', so you may need to tweak some of the transformers.
  • Jul 13, 2022 7:27 AM UTC
Thank you very much for your help. Both solutions are very good. Thank you
