Hi, How can I copy data from say a CSV file with one record too many records from another file? If you have a common record header you can use the feature merger but I don't have anything common. Is there a way to do that?
Best answer by jdh
You can use the featureMerger.
you can set both the requestor and supplier join on values to a constant like 1 rather than an attribute.
