Hi FME Team. I am using the same login and password for connecting to PostSQL database to complete the training module, and I keep getting connecting errors every time I try to run sample data, do you know how to remove that error?
  • Jan 22, 2024 12:18 AM UTC
  • 56 views
PostgreSQL database login details
Host: postgis.train.safe.com
Port: 5432
Dbname: fmedata
User:fmedata
password: fmedata (not sure if it is that password) (getting ***)
Best answer by samatsafe
Hello @benjaminj​, I can also confirm I can access the database right now. As @Hans van der Maarel​ said, it's most likely a firewall or other network issue preventing access. I'd contact your IT department or review your firewall settings. If you are using a VPN, I'd recommend trying to connect without a VPN as well; that is sometimes the culprit.
Forum|alt.badge.img+63
I've just checked and the database is working for me, so it's not down (at least not right now). It's likely there's a firewall preventing you access. Which errors specifically are you getting?
itsmatt
Forum|alt.badge.img+48
  • Jan 22, 2024 12:54 PM UTC
I can also confirm the connection using those details - I used PGAdmin to connect
samatsafe
Forum|alt.badge.img+12
  • Jan 22, 2024 5:22 PM UTC
