Hello, I need to add two vertex (points) to one polygon. I need to join them to the nearest vertex of this polygon.
  • Nov 13, 2020 10:05 AM UTC
  • 142 views
wind
I need to add two vertex (points) to one polygon. I need to join them to the nearest vertex of this polygon.  I have this:
dataAnd I need this result:
resultThank you
  • Nov 13, 2020 10:22 AM UTC
You could try using the AnchoredSnapper in mode Vertex Snapping. The points are the Anchors and the polygon is the Candidate. Note that the snapping distance is specified in ground units relative to your coordinate system.
wind
  • Nov 13, 2020 10:41 AM UTC
Thank you very much.
I try the AnchoreSnapper but it doesn't work like I need. The distance I specifie is 13200 but it joins the vertex of 22000. Is it possible to join the nearest vertex, without the distance?
result1
Forum|alt.badge.img+54
  • Nov 13, 2020 10:59 AM UTC
I don't think the anchored snapper will work here because it will move the corner vertices rather than add additional vertex. I'd use the neighbourfinder to find the closest point on the polygon then a vertex creator to create a line from point to polygon, separately i'd create a line between your two points and then a line combiner and line closer followed by a dissolver
Capture
  • Nov 13, 2020 11:11 AM UTC
result1
Yup, @ebygomm​  is right, the AnchoredSnapper isn't the right tool here. My mistake.
