Hello, everyone, I have the following problem: There are many polygons in the reader (dgn) and there is a text in each polygon. I would like to write these polygons in a DWG (writer) and assign the text to the polygon as "Extended_Data".
  • Sep 28, 2021 3:12 PM UTC
  • 111 views
To make matters worse, the extended data need a certain form (for example "CODE 1004 - Binary Data").
I have already found some impulses in the forum (autocad_extended_data_list {}), none of which helped me to solve the problem.
Does anyone have any ideas or food for thought from you?
Many greetings
Martin
drc43
Forum|alt.badge.img+13
  • Sep 28, 2021 4:00 PM UTC
Hi @martinmel​ ,
In my experience, extended data in a DWG is only possible on a block. I have never been able to output lines or polygons with extended data, from FME or directly in AutoCAD. If I am wrong, perhaps another community member can educate both of us, but I've never got this to work.
  • Sep 29, 2021 6:02 AM UTC
Hi @drc43​ ,
thank you for your quick reply.
Unfortunately, it doesn't help me any further: you can assign attributes to a block.
But that's not my job.
I want to assign extended data to a polyline.
These can be queried in ACAD using the "XDATA" command and look like this, for example:
* Registered Application Name: DCO15
* Code 1071, 32-bit signed long integer: 1
* Code 1000, ASCII string: G10_KEY
* Code 1004, Binary data not printed.
When I read a DWG with objects including xdata, I use the format attribute "autocad_extended_data_list {}" and can write the objects to a new DWG without data loss.
But now I have a DGN without XDATA.
When writing the DWG, I want to assign XDATA to the objects. My attempts with the AttributeCreater all failed.
