Grouping attribute range
  • Jan 16, 2019 3:05 PM UTC
  • 134 views
want to do something like this in FME
Original Table
Age
Number
0-10
5
10-20
10
20-30
230 plus
4
Create new attribute with range values or group values in Name field by ranges.
The only way I can think of is to use Attribute Creator and use conditions to set up each category range. I am hoping there is an easier way of doing this.
Lee!
Best answer by ebygomm
Take a look at the AttributeRangeMapper
Forum|alt.badge.img+54
  • Jan 16, 2019 3:12 PM UTC
itay
Forum|alt.badge.img+19
  • Jan 16, 2019 8:14 PM UTC
Or the In Range operator in the attribute creator/manager, using conditional values. (which is basically the same as the AttributeRangeMapper)
