Getting memory not enough errors when opening larger data layers in FME data Inspector
  • Jan 9, 2024 2:41 PM UTC
  • 57 views
kuangk
Participant
It seems ok when adding smaller data layers but couldn't add bigger layers. I was getting memory not enough error message but my memory is only used one third.
bayram
Forum|alt.badge.img+7
  • Jan 9, 2024 3:06 PM UTC
hi
You can check the "C" area of ​​your computer. If the memory is filling up fast while WB is running, you can purge from time to time in the tools section. You can also delete the garbage files accumulated there by typing %temp% in the search field of your computer.
kuangk
Participant
  • Participant
  • Jan 9, 2024 3:24 PM UTC
When you say in the tools section, where is it? In Windows or FME?
kuangk
Participant
  • Participant
  • Jan 9, 2024 3:26 PM UTC
never mind, found it
kuangk
Participant
  • Participant
  • Jan 9, 2024 3:29 PM UTC
Just tried and it worked. Thanks.
