getting error like "Unable to convert row to 'DimensionFeature' " while reading a Dimesions file.
  • September 16, 2021
  • 55 views
swethabhupathi
Forum|alt.badge.img+4
I am trying to read an arcgis dimensions file from an sde . While reading i am getting the error "Unable to convert row to 'DimensionFeature'".
i need to read the dimesions and need to convert them as a line feature.
can you please hep me to resolve this issue.
danminneyatsaf
Forum|alt.badge.img+12
Hi @swethabhupathi​, are you using ArcGIS Pro? I ask this because unfortunately ArcGIS Pro Dimensions are not supported since it's a new model/library that was implemented with ArcGIS Pro. The workaround to this would be to write Dimensions using ArcMap/ArcCatalog.
swethabhupathi
Hi, May i know is the ArcPro Dimensions will be able to read using 2022 version of fme ?
