Get Corner Coordinates of pixels with color
  • March 20, 2023
  • 11 views
Hello,
i need to georeference 800 maps.
Every map is from a grid that is 1km x 1km.
From the Scanning and the old paper it can be that the Map has a angle just like showing in the example picture below.
Is it possible to get the coordinates of the 4 Red points and set them to the coordinates that the Picture should have from the grid?
I know how to do it with the bounding box but i dont know how to deal with the transparency.
or is there a better way to make the georeferencing of 800 picutres more easy?
Example
daveatsafe
Forum|alt.badge.img+19
  • March 20, 2023
Hi @fluusha​,
The RasterExtentsCoercer transformer may be helpful here, if you use the Data Extents option. This will give you the bounding polygon around the non-transparent area of the raster.
