Geodatabase Error (-2147219884): The Field already exists
  • March 29, 2021
  • 276 views
caracadrian
Forum|alt.badge.img+23
I want to reopen an old case that is still of interest:
Geodatabase Error (-2147219884): The Field already exists (safe.com)
My error isn't of the "reserved word" origin nor related to having "shape" as an attribute name.
When trying to dynamically create tables in a GDB I get the "Field already exists" error.
2147219884_ErrorIf I send each feature type to a corresponding table it runs.
No ErrorFor what I am trying to do, connecting readers and writers by hand is not worth it.
Can someone from Safe comment on this?
Best answer by nielsgerrits
I have attached a screenshot of the writer and the workspace.
gdb writer
I can reproduce your issue, but when using FeatureReader/FeatureWriter instead of classic Reader/Writer it works, but with a bunch of warnings.
2021-03-30_09h26_13
hkingsbury
Forum|alt.badge.img+67
  • March 29, 2021
How are you passing the schema through to the writers? Can you shouw us the configuration of your writer(s) in the first example?
caracadrian
  • March 30, 2021
gdb writer
nielsgerrits
Forum|alt.badge.img+64
  • March 30, 2021
gdb writer
2021-03-30_09h26_13
braggken
Forum|alt.badge.img+7
  • August 11, 2021
I think the source of this problem might be the objectid field. If a geodatabase is the schema source then the dynamic writer tries to add the objectid field to the output but in fact this field is automatically created whenever a geodatabase feature class is created. I personally solved it in the destination feature types using the parameter "Attributes to Remove" and entering objectid
2021-08-11 11_48_55-Feature Type
