Geocoder transform
  • Nov 23, 2023 2:22 PM UTC
  • 223 views
massizurli
I'm testing Geocoder transoform. It works well with ArcGIS Online. With OSM I have this error:
Geocoder_2_CALLER: HTTPSConnectionPool(host='nominatim.openstreetmap.org', port=443): Max retries exceeded with url: /?format=json&q=Strada+Villa+17%2C+37010+Cavaion+Veronese%2C+Italy (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTI...
I use FME(R) 2022.2.1.0 (20221202 - Build 22776 - WIN64) for ArcGIS (Data Interoperability extension).
  • Nov 23, 2023 2:29 PM UTC
I'm guessing you're sitting behind a corporate proxy that uses a custom CA certificate? The proper solution would be to install the custom CA certificate on the machine you're on, but short term you could simply turn of certificate verification, although from a security standpoint it's not really ideal:
massizurli
  • Nov 23, 2023 2:37 PM UTC
I had tried with that setting but without success. I copied the workbench to a server where I have a valid certificate and it works. Thank you!
