Generate smooth curve between points
  • Sep 10, 2020 6:28 PM UTC
  • 258 views
warrendev
Forum|alt.badge.img+28
I have a set of 2d points that I need to generate a smooth curve between all points. My goal is to either take a polyline or a set of points and generate a spline between all of the points for a best fit and write this out to a DWG.
I'm trying to figure out which transformers would be best to build this. I just need to make sure that the spline passes through each point for a best fit.
spline
Best answer by warrendev
Easier than I thought. Just needed to build the line with the linebuilder and send the polyline to the DWG writer after setting the attribute "autocad_entity" to "autocad_spline" and it will draw it correctly at write time.
spline
warrendev
  • Sep 12, 2020 9:17 PM UTC
spline
