Forcing excel writer to use new line
  • Apr 30, 2021 5:01 PM UTC
  • 7 replies
  • 177 views
Hi
Can you please advice on how can i force the excel writer to use new line for multiple records. For example making a list of IDs instead of having the whole text as one line. Below is an example where the red is what i want to avoid, having to do it manually in excel, the green what I want to achieve.
Untitled
  • May 2, 2021 11:10 AM UTC
Hi @dionysios​ , if you need to split a text line by some pattern and create new lines for each resulting split element, combination of the StringSearcher and the ListExploder might help you.
I don't know if it's correct, but it seems that "A*N*-EWC-****" (* is a digit) is the basic pattern and sometimes suffix "-a" or "-b" is added.
Could you please elaborate the correct pattern that should be applied to split the text line?
hkingsbury
Forum|alt.badge.img+73
  • May 2, 2021 8:10 PM UTC
I'd follow this approach, using the regex functionality in the string searcher will allow you to split out the individual parts
(A\dN\d-EWC-\d{4}(-[a-zA-Z]\d?)?)
'A\dN\d-EWC'-  will find a string that begins with an 'A', followed by a digit (0-9) followed by a 'N' , follwed by a digit and ending with '-EWC-'
'\d{4}' will find four digits in a row
'(-[a-zA-Z]\d?)?' is an optional statement (denoted by the '?' meaning zero or one). It will match a string that begins with a '-' followed by any letter (case insensitive) follow by an optional digit
  • May 3, 2021 11:54 AM UTC
@hkingsbury​  @Takashi Iijima​  hi guys, thanks for the reply. The problem is not really finding the pattern which its really always same format, easy to use a regex. I just cant make it write on excel as a list, one below the other. This however gives me some ideas, probably find the values with attribute manager before writting them on the excel. Thank you both
Forum|alt.badge.img+54
  • May 4, 2021 8:46 AM UTC
Do the linefeeds already exist in your string?
Have you set the wrap text option on the attribute in the formatting options?
Capture
  • May 4, 2021 12:09 PM UTC
Capture
hi @ebygomm​ yes i did try that one too. It did not work, i guess because i am using the attribute manager with @values from different attributes. i am going to play a bit more with different options.
  • May 4, 2021 12:17 PM UTC
Capture
So your AttributeManager looks something like this?
CaptureIf the linefeeds are present and the column is set to wrap text it should just work.
  • May 4, 2021 3:53 PM UTC
Capture
That is exactly how it looks but it didnt work.
