For some reason the HTTPCaller doesn't yield any output on FME Server, but does on FME desktop
  • December 1, 2022
  • 143 views
joy
Forum|alt.badge.img+15
  • 88 replies
For some reason the .fmw script does work on FME desktop ( 2021.2.3) and does yield an output (in my case a geojson). When I import the script on FME Server (version 2021.2.4) then the script is completed without raising any error, but doesn't write the file on a map. I am quite sure that  the Published parameter "Destination JSON file" is correctly written.
When I look at the view details tab after the script has been completed, I see a lot of statements with Nuke or TeeFactory. I read on the following link in the answer of merlingeorge: https://community.safe.com/s/question/0D54Q00009fDZGRSA4/disabled-nuker-1-50-teefactory- that it might have to do with version incompatibility. Might that also be the case in my situation? I would assume there wouldn't be much differences between FME desktop 2021.2.3 en 2021.2.4. By the way, some lines below have been omitted due to security concerns.
40	2022-12-1 15:38:40 | Creating writer for format:
41 2022-12-1 15:38:40 | Creating reader for format:
42 2022-12-1 15:38:40 | MULTI_READER(MULTI_READER): Will fail with first member reader failure
43 2022-12-1 15:38:40 | Using Multi Reader with keyword `MULTI_READER' to read multiple datasets
44 2022-12-1 15:38:40 | Using MultiWriter with keyword `MULTI_WRITER' to output data (ID_ATTRIBUTE is `multi_writer_id')
45 2022-12-1 15:38:40 | Writer output will be ordered by value of multi_writer_id
46 2022-12-1 15:38:40 | Loaded module 'Geometry_func' from file 'D:\Program Files\FMEServer\Server\fme\plugins/Geometry_func.dll'
47 2022-12-1 15:38:40 | FME API version of module 'Geometry_func' matches current internal version (3.8 20210302)
48 2022-12-1 15:38:40 | Loaded module 'HTTPFactory' from file 'D:\Program Files\FMEServer\Server\fme\plugins/HTTPFactory.dll'
49 2022-12-1 15:38:40 | FME API version of module 'HTTPFactory' matches current internal version (3.8 20210302)
50 2022-12-1 15:38:40 | Emptying factory pipeline
51 2022-12-1 15:38:40 | Creator_CREATED Disabled Nuker -1 16 (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
52 2022-12-1 15:38:40 | Creator_for_Token_2_CREATED Brancher -1 17 (BranchingFactory): Branched 0 input features -- 0 features routed to the target factory, and 0 features routed to the fallback factory.
53 2022-12-1 15:38:40 | Creator_2_XML_Creator (CreationFactory): Created 1 features
54 2022-12-1 15:38:40 | Creator_2_Cloner (TeeFactory): Cloned 1 input feature(s) into 1 output feature(s)
55 2022-12-1 15:38:40 | Creator_2_CREATED Brancher -1 22 (BranchingFactory): Branched 1 input feature -- 1 feature routed to the target factory, and 0 features routed to the fallback factory.
56 2022-12-1 15:38:40 | _CREATOR_BRANCH_TARGET (TeeFactory): Cloned 1 input feature(s) into 1 output feature(s)
57 2022-12-1 15:38:40 | HTTPCaller_3 Output Transformer Output Nuker (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
58 2022-12-1 15:38:40 | HTTPCaller_3 <REJECTED> Transformer Output Nuker (TeeFactory): Cloned 1 input feature(s) into 0 output feature(s)
59 2022-12-1 15:38:40 | HTTPCaller_2 (Disabled) Nuker (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
60 2022-12-1 15:38:40 | HTTPCaller (Disabled) Nuker (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
61 2022-12-1 15:38:40 | Destination Feature Type Routing Correlator (RoutingFactory): Tested 0 input feature(s), wrote 0 output feature(s): 0 matched merge filters, 0 were routed to output, 0 could not be routed.
62 2022-12-1 15:38:40 | Final Output Nuker (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
63 2022-12-1 15:38:40 | =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
64 2022-12-1 15:38:40 | Features Read Summary
65 2022-12-1 15:38:40 | =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
66 2022-12-1 15:38:40 | ==============================================================================
67 2022-12-1 15:38:40 | Total Features Read 0
68 2022-12-1 15:38:40 | =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
69 2022-12-1 15:38:40 | =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
70 2022-12-1 15:38:40 | Features Written Summary
71 2022-12-1 15:38:40 | =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
72 2022-12-1 15:38:40 | ==============================================================================
73 2022-12-1 15:38:40 | Total Features Written 0
74 2022-12-1 15:38:40 | =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
75 2022-12-1 15:38:40 | Translation was SUCCESSFUL with 0 warning(s) (0 feature(s) output)
76 2022-12-1 15:38:40 | FME Session Duration: 0.4 seconds. (CPU: 0.1s user, 0.0s system)
77 2022-12-1 15:38:40 | END - ProcessID: 2116, peak process memory usage: 49868 kB, current process memory usage: 49868 kB
nielsgerrits
Forum|alt.badge.img+60
  • 2938 replies
  • December 2, 2022
The line
makes me think HTTPCaller_3 is outputting a rejected feature. What does it say? Connect a Logger transformer to the Rejected outputport to display the content of the rejected feature in the log.
With version differences, I do not expect this (server being slightly newer than desktop) to be the issue, but hard to say without testing.
About server 2021.2.4, please check the article Known Issue: FME Server missing validation which may result in an unwanted redirect upon login to determine if you should upgrade.
joy
  • 88 replies
  • December 2, 2022
The line
@nielsgerrits​  My colleague put a logger after the rejected output port and was able to solve the issue with the information from the logger.
