FME Workbench 2018 x64 crashing on exit
  • October 3, 2018
  • 46 views
Newly installed FME Desktop Oracle Edition 2018.1.0.2 Build 18547 - WIN64 crashing on exit. fmeworkbench.exe remains in Task Manager.
Event Viewer error shows ucrtbase.dll as a faulting module.
FME is installed on Windows Server 2008 R2 Standard SP1. I tried repairing and also reinstalling FME but nothing helps.
  • October 3, 2018
Sounds like it might be related to a known issue with Windows updates. Take a look at the following article for more details:
https://knowledge.safe.com/articles/63592/fme-exe-has-stopped-working-after-updating-windows.html
  • October 3, 2018
Maybe it is somehow related but we have neither ESRI products installed nor the mentioned Windows Updates KB4056894/KB4056897. The faulting module is also different.
I have just tested latest FME 2017 x64 and it works just fine.
xiaomengatsafe
Forum|alt.badge.img+11
Hi @denisnaumov, thank you for letting us know that you are running into this issue. I think we need to work more closely with you to figure out went wrong. Would you mind submitting a problem report for this defect? You can reference this Q&A; thread for details on the issue, in your problem report. Thank you very much!
  • October 19, 2018
Any help at all? Would you advise running this unstable version?
