FME through Windows Task Scheduler
  • Jun 14, 2023 11:16 AM UTC
  • 231 views
I have a workspace which is scheduled through Windows Task Scheduler on a Virtual Machine. This workspace writes out to an Excel file on a mounted drive. When running the workspace manually, it has no issues. However when running through Task Scheduler, the workbench gives an error "Can't open file for writing". The target Excel is not opened anywhere and I do have writing permissions for it.
Has anyone dealt with a similar issue before?
Best answer by ebygomm
Are you trying to write to a mapped network drive? If so you probably need to use the UNC path
Forum|alt.badge.img+63
Does the account that's running the task through task scheduler have access to the file/directory?
kailinatsafe
Forum|alt.badge.img+24
I think @redgeographics is onto something, see the "Won't Get Fooled Again" section of this article! Best, Kailin
Forum|alt.badge.img+54
  • Jun 14, 2023 3:44 PM UTC
  • Jun 15, 2023 7:05 PM UTC
This worked! Thanks a million for your help.
