FME suddenly getting unexpected errors
  • November 29, 2023
  • 104 views
rmpayaby
Forum|alt.badge.img+3
I am running an FME-routine in FME Desktop (2022.2) where I want to modify data from an ESRI Geodatabase and write them back to another ESRI Geodatabase. This routine has always worked fine for months until recently, where it suddenly gets the following error messages in the log-file:
2023-11-28 20:05:40|6109.0|  0.0|ERROR |An error occurred while attempting to insert a row into the table 'UPDATE_TABLE' using a cursor. The error number from ArcObjects is'-2147155558'. The error message from ArcObjects is: {Overflow or value larger then maximum 32bit integer [UPDATE_TABLE]}
2023-11-28 20:05:40|6109.0|  0.0|STATS |Storing feature(s) to FME feature store file `D:\LOGS\Matrikkeloppdatering_log.ffs'
Any tips on how I should resolve this issue? Is it related to version compatibility? I am currently using ArcGIS Pro 3.1.2.
Forum|alt.badge.img+50
Can you check that .ffs file that's being written, that should contain the feature(s) that trigger this error so if you inspect them you may find what's wrong.
The error message refers to an overflow error in a 32-bit integer value, they can range from -2,147,483,648 to 2,147,483,647 (or 0 to twice that last value if it's unsigned). Is it possible you have an attribute value that falls outside of that range?
rmpayaby
  • November 29, 2023
I have checked the .ffs file and it seems like that's the case. Is there any way to change the data type to a 64-bit integer instead?
You should be able to set that on the writer feature type. However, it looks like you're updating an existing table, in which case I'm not sure changing data types is allowed (or advisable)
