FME Shutdown Script - fme.totalFeaturesRead and fme.totalFeaturesWritten evaluated to 0 in dynamic workflow
so_much_more
I want to log some workbench results directly to a database. As a template to start from I followed this example https://community.safe.com/s/article/shutdown-python-scripts-in-fme#ex3
Works greeat, only issue is fme.totalFeaturesRead and fme.totalFeaturesWritten evaluates to 0 when there are 10'' objekts in my workbench which is dynamic.
How would one go about to get the totalFeaturesRead and written for a dynamic workbench?
fme.totalFeaturesRead i evaluated if a regular reader is used. But i am using FeatureReader / Writer - in that case it is not reported. But why not?
virtualcitymatt
Forum|alt.badge.img+36
Yeah it's a known issue with the featureReader/Writer: https://community.safe.com/s/bridea/a0r4Q00000HbrxCQAR/include-featurewriter-counts-in-the-total-features-written-stats
You can vote on the idea and link this Question
virtualcitymatt
You should also keep in mind that the FeaturesWritten summary data isn't always accurate - there are instances where a feature is counted as written but is actually skipped (because of inalid data for example)
You can read a bit more about it here
https://community.safe.com/s/question/0D54Q000080hTJTSA2/featurewriter-silently-dropping-bad-features-and-total-features-written-count-is-wrong
