FME Server will not run new workspaces after upgrade, goes imidiately into queue and then fails without creating log file
atle_hoidalen
Forum|alt.badge.img+3
Hi! I have been running FME Server 2019 for a year now without any problems. Upgraded both server and Workbench to 2020.1 two weeks ago and initially everything seemed fine. However, I discovered that new workspaces that I upload to Server will not run. The jobs imidiately goes into queue and then fails shortly after. No log file is created. All the old excisting workspaces are running as normal.
  • October 5, 2020
Have you checked the server logs?
atle_hoidalen
Checked now, I can see the following message "FME Engine failed to register with FME Server 'MC-FME01' on port 7070. Program terminated". When I run new workspaces. However, this message appears also when running the "old" workspaces but these are run successfully anyway... I will ask for help from my IT-department and do some more testing and report back.
