FME Server REST API Return File Extensions for File Upload
  • February 20, 2022
  • 0 replies
  • 18 views
warrendev
Forum|alt.badge.img+23
I've built a python fastapi web application using the FME Server REST API and was wondering if I'm overlooking where the file extension filters are returned for any file parameters. While I see all of the other parameter information, I am not seeing the file extensions specified in the workspace for a parameter. It does not show this in the REST API call for /repositories/< repository >/items/< item >/parameters, so I was wondering if it is somewhere else or not available at all.
Is this a limitation to the FME Server REST API perhaps? The reason for this is that my application is fully dynamic, so the FME workspace drives the creation of the form inputs.
Be the first to reply!
