FME server app error: Unauthorized request by user due to lack of proper permissions for connection
  • March 22, 2023
  • 258 views
I have a workspace with a sql connection which can be ran with "run workspace" tool on FME server. However when I published it as a FME Server App (No authentication required) and ran the app resulted in this error. From completed jobs in FME Server UI, the two runs have the same user. And the user has full access to and is the owner of the connection. What could be the issue?CaptureCaptureimage
merlinegeorge
Forum|alt.badge.img+5
Hello @zhangjinzhou ,
This article would be a good starting point for troubleshooting this issue. Could you please go through it and see if it resolves the issue?
