FME Revit to dwg converter - need a 2021 version
  • September 17, 2021
  • 234 views
the current converter version is just for 2019 Revit, we are in 2021. Can we have the FME converter for this 2021 version or the update
kailinatsafe
Forum|alt.badge.img+21
Hello @lemyreeric​ , according to our documentation, currently, the Revit reader in FME 2021.x supports Revit versions 2015-2021. May I ask what version of FME you are using? I think this should work as long as you are using a FME 2021 version/build. You can find this on our Downloads Page. Also, Revit 2022 support is planned for FME 2022! Best, Kailin.
  • September 22, 2021
Thanks for you quick response. I did download the correct version on your download link. Seem to be a bit hard to converting a rvt to a dwg file ? The link Convert RVT to DWG - View Your Revit Data in AutoCAD (safe.com) is talking about a pluggin that sould be in the Add-ins toolbar of my 2021 Revit but seem not. Im a bit confuse and i do want to try a converter that can help me.
kailinatsafe
Hello @lemyreeric​ , there shouldn't be a need for the Exporter here. Ideally you will: 1) Export Revit data to IFC using the built-in IFC Exporter, 2) Use IFC as Data Views Reader to read into FME Workbench. Let me know if you have any success with this or if it doesn't work for you. Here to help, Kailin.
