FME Rejection code : `INVALID_CANDIDATE_GEOMETRY_VERTICES'
  • Sep 20, 2019 8:24 AM UTC
  • 736 views
rakeshreddy0996
im tring to run NeighborFinder it shows error like below
The below feature caused the translation to be terminated
Storing feature(s) to FME feature store file `.\\mapping_log.ffs'
Feature Type: `FEATURE_TYPE'
Attribute(string) : `#ADDRESS' has value `Hastings Dr'
Attribute(string) : `#BLDGUNIT' has value `'
Attribute(encoded: utf-8) : `#HBAP' has value `10245,,Hastings Dr,20110'
Attribute(string) : `#HOUSENUMBER' has value `10245'
Attribute(string) : `#POSTALCODE' has value `20110'
Attribute(encoded: utf-8) : `HBA' has value `10245,,Hastings Dr'
Attribute(string) : `fme_feature_type' has value `CSV'
Attribute(string) : `fme_geometry' has value `fme_undefined'
Attribute(string) : `fme_rejection_code' has value `INVALID_CANDIDATE_GEOMETRY_VERTICES'
Attribute(entangled: string): `fme_type' has value `fme_no_geom'
entangled to [csv_type]
Coordinate System: `'
Geometry Type: IFMENull
Please suggest ASAP
Best answer by mileslee
Hi @rakeshreddy0996, from the description, one of your input file should be from CSV as it shows "fme_feature_type' has value `CSV'", which might have no geometry but only have the attributes. This could be proved by "fme_geometry' has value `fme_undefined'" as well, which results in "INVALID_GEOMETRY". What I think is you could use "VertexCreator" transformer to create the geometry for your CSV input feature, to solve this issue.
Forum|alt.badge.img+63
Looks like it's a null geometry, i.e. an object without geometry. That'll throw off the NeighborFinder. You can use a GeometryFilter to filter out those objects.
  • Sep 21, 2019 12:03 PM UTC
