FME- python install paramiko: Expected an even number of command line arguments, instead got 9
  • Aug 28, 2020 1:26 PM UTC
  • 190 views
Hello everyone,
I recently tried to install the paramiko library in my FME environment using the command:
fme.exe python -m pip install paramiko --target C:\\Users\\NMI\\Documents\\FME\\Plugins\\Python
On my local machine it works as expected. When I try to install it at the customer however it fails with the error message: Installing build dependencies: finished with status 'error'
Further in the log it returns the following information (newline characters have been added to improve the readability):
Expected an even number of command line arguments, instead got 9 for command line: >>
`pip'
`install'
`--ignore-installed'
`--no-user'
`--prefix'
`C:\\Users\\NMI\\AppData\\Local\\Temp\\pip-build-env-ilnw8_md'
`https://files.pythonhosted.org/packages/c3/a9/5dc32465951cf4812e9e93b4ad2d314893c2fa6d5f66ce5c057af6e76d85/setuptools-49.6.0-py3-none-any.whl#sha256=4dd5bb0a0a0cff77b46ca5dd3a84857ee48c83e8223886b556613c724994073f'
`https://files.pythonhosted.org/packages/a7/00/3df031b3ecd5444d572141321537080b40c1c25e1caa3d86cdd12e5e919c/wheel-0.35.1-py2.py3-none-any.whl#sha256=497add53525d16c173c2c1c733b8f655510e909ea78cc0e29d374243544b77a2'
`https://files.pythonhosted.org/packages/c6/8f/dfb115c3ff7fdfb49e47d0e4cd0566c62e94427e90e22f0e5f6ec84be7d9/cffi-1.14.2-cp37-cp37m-win_amd64.whl#sha256=e4b9b7af398c32e408c00eb4e0d33ced2f9121fd9fb978e6c1b57edd014a7d15'
Has anyone encountered a similar issue before?
All help is greatly appreciated.
Best answer by debbiatsafe
Hi @kd​
What version of FME is installed on your local machine versus the customer's machine?
I was able to replicate a similar error using FME 2020.0 and older. I believe you are seeing this behaviour due to a bug where FME is unable to install Python packages distributed as *.tar.gz.
This issue has been fixed in 2020.1 builds. Are you able to try on the customer machine using 2020.1?
debbiatsafe
Forum|alt.badge.img+24
  • Aug 28, 2020 8:55 PM UTC
Hi @kd​
  • Sep 1, 2020 12:59 PM UTC
Hi @kd​
Hi @debbiatsafe (Safer)​ ,
Installing FME 2020.1 did the trick. Everything works as expected now.
It's a bit weird though that it did work on my own machine initially since I was using the exact same build number as the customer (2020.0.2.1 - Build 20238 - win64).
Thanks for the support!
