FME_LOGGEDIN_USER parameter Capture
  • January 24, 2023
  • 47 views
Hi
We are currently on FME Server 2021.2.2. There's a need to capture the login user ID for a server app and then insert into our database for logging purpose:
imageBelieve that's the FME_LOGGEDIN_USER parameter. Please advise whether it is possible to do so. Thanks.
Best answer by redgeographics
It's FME_SECURITY_USER, and yeah, you can capture that into an attribute with an AttributeCreator and then write it to a database.
Forum|alt.badge.img+62
  • January 24, 2023
dustin
Forum|alt.badge.img+31
  • January 24, 2023
I have also used 'FME_SERVER_RUNTIME_USER' in the past for getting the logged in user.
  • January 24, 2023
Thanks @Hans van der Maarel​ . That makes sense. Is FME_SECURITY_USER available in FME Server version 2021.2.2 or we need to upgrade to latest version? Also where can i locate FME_SECURITY_USER?
  • January 24, 2023
NVM found it:
security usere
Thanks!
