FME Desktop license manager
  • May 15, 2021 4:05 AM UTC
  • 314 views
Hi with a floating license setup, is there a way to manage licences in use? I.E kick specific, known inactive sessions off to free up licenses?
Best answer by todd_davis
Yes, it is using FlexLM and its a is/was a widely used license manager that is detailed well on the internet.
For instance using the lmutil.exe you can get the list of users and the version they are using
lmutil.exe lmstat -c @<host> -a
And then you can use functions like
lmutil.exe lmremove to remove users.
todd_davis
Forum|alt.badge.img+23
  • May 15, 2021 11:53 PM UTC
  • May 16, 2021 12:19 PM UTC
Excellent thank you this helps a lot. Note I could not figure it out with the standard instructions for FLEXlm, but this you tube video helped.
  • May 17, 2021 8:05 AM UTC
Also be sure to check out the documentation in "LicenseAdministration.pdf", which you'll find in the Documents subfolder of the Flexserver installation.
