FME Desktop and PythonCaller
  • September 21, 2020
  • 27 views
Hello,
I have a program to make that require the use of a PythonCaller. But unfortunately, it looks very different to what I am used to, doing Python work.
I have looked up for some tutorials on how the input/output woks, but I have not found anything really useful, or even understandable.
Do you have any link for a tutorial that goes further than just launching a PythonCaller ?
I need to modify a SHP file, deleting some lines/geometry points and adding some, as well as features. All in 3D
Thank you
Best answer by anhphuongt
I think this will help:
https://community.safe.com/s/article/python-and-fme-basics
Especially that part about PythonCaller Transformer:
https://community.safe.com/s/article/pythoncaller-transformer
anhphuongt
  • September 22, 2020
Hi @theodore​ , every transformer having an input port requires an input feature to run.
If all you need is to just run the script written in the PythonCaller, add a Creator transformer to the workspace and connect its output port to the input port of the PythonCaller.
Just be aware that FME calls "input" method of a class or a function whose name was specified through the Class or Function to Process Features parameter in the PythonCaller, when a feature is arrived.
FYI, the PytonCreator too executes a Python script, but it requires no input features.
