FME Desktop 2020: The “clipper” tool fails to generate the expected result,
  • Dec 20, 2021 5:46 PM UTC
  • 5 replies
  • 96 views
jamal
Forum|alt.badge.img+5
In the screenshot below, I wanted to clip the blue color from the red color. As there is not intersection between these two colors, the result should be the red color itself. However, the result not exactly the red color.
What could be the issue here?
Clip_1382
Clip_1383
Clip_1384
Clip_1385
The data and the work bench are attached
Best answer by caracadrian
There seems to be a "bug" in the feature geometry.
If you insert a GeometryRefiner (I inserted it after GeometryCoercer) FME should give you the correct result.Refiner
caracadrian
Forum|alt.badge.img+23
  • Dec 21, 2021 5:38 AM UTC
jamal
  • Dec 21, 2021 5:34 PM UTC
Thank you caracadrian for the help.
Does the “geometryrefiner” tool change the original geometry?
Clip_1398
caracadrian
  • Dec 21, 2021 6:07 PM UTC
Clip_1398
This is a trick question 😀
It does but it doesn't...
If you are thinking at vertices, lines, arcs and so on, it doesn't.
If you are thinking at path and curves, it does.
I think the help explains it best:
  • Any homogeneous IFMEAggregate will become a multi (IFMEMultiCurve, IFMEMultiArea, IFMEMultiPoint, or IFMEMultiText).
  • Any IFMEAggregate or multi with only one member will be replaced by its single part.
  • Any IFMEDonut with no holes will become an IFMEPolygon or IFMEEllipse.
  • Any IFMEPath with only one segment will be replaced by that segment.
  • Consecutive IFMELine segments within an IFMEPath will be combined.
https://docs.safe.com/fme/2021.2/html/FME_Desktop_Documentation/FME_Transformers/Transformers/geometryrefiner.htm
jamal
  • Dec 21, 2021 8:17 PM UTC
Thank you for the input. This is very useful
jamal
  • Mar 15, 2022 6:35 AM UTC
I found out that the “geometryrefiner” tool does change the geometry and appears not to bring the solution we are looking for.
I’m not sure if this bug is going to be fixed soon
Could be there a tool that can IDENTIFY the cause of this issue such that it can be fixed at the level of the source of data (AutoCAD)?
