FME Desktop 2020: How to display the result of workbench (graphic and table) stored in esri file geodatabase in the “visual preview”?
I couldn’t figure out how to display the result of workbench (map and table) stored in esri file geodatabase in the “visual preview”. This is already doable for tools.
Best answer by itsmatt
I think that visual preview has been disabled on writers.
But if you want to inspect the out put you just need to click on the little icon above the output feature type which looks like a magnifying glass over a database. This should put it in the visual preview window.
