FME datetime question
  • January 23, 2024
  • 5 replies
  • 142 views
naveen
Forum|alt.badge.img+7
Hello - I am retrieving value from "date" field using ArcGIS portal services . It seemed to be in this datetime format ( YYYYMMDDHHMMSS like below screenshot) on UTC time. I would like to change this to local time. Please help on how this can be achieved. Tried using datetime converter, but does not seem to work .
image.pngThanks,
Naveen
Best answer by nielsgerrits
The DateTimeConverter is used to change the format, not to change the timezone. Also, you know the original data is UTC, but for the machine to know that it needs +00:00 added.
If you want to go from 20230821160000 UTC to local time, you can use @TimeZoneSet() in the AttributeCreator. See the documentation.
I think you need
@TimeZoneSet(@TimeZoneSet(20230821160000,utc),local)
which takes you datetime, set it to utc (adds +00:00) and converts that to your local timezone.
Forum|alt.badge.img+62
What have you tried in the DateTimeConverter?
f.kemminje
Forum|alt.badge.img+11
  • January 23, 2024
pls refer this
safe1
nielsgerrits
Forum|alt.badge.img+64
  • January 23, 2024
I think you need
naveen
  • January 24, 2024
I think you need
@nielsgerrits​ This worked. Thanks so much.
nielsgerrits
Cheers :)
