FME 2022 Build22153: Calculating the value of an attribute fails,
In the screenshot below, I wanted to calculate the “BuildingPercent” attribute field by dividing “BuildingArea” field on “BoundaryArea” field but appears not to work. It doesn’t perform the calculation.
What could be the issue here?
The data and the workbench are attached
Best answer by geomancer
Hi @jamal - The AttributeCreator needs to know you are wanting to do a calculation with those fields, so you need to wrap it with @Evaluate()
So, for your example, the attribute value needs to be:
