FME 2020: “Schemamapper” tool fails to map Arabic fonts,
  • Jan 3, 2021 9:06 PM UTC
  • 87 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out why the “Schemamapper” tool fails to map Arabic fonts
Clip_160
Best answer by rahulsharma
Hi @jamal​
Can you check the following
  • what is the current locale? does it understand Arabic characters?
  • Are the values before the SchemaMapper correct when logged(not in Data Inspector)?
  • can the locale be switched to either Arabic or UTF-8 on the current OS?
If you are on Windows 10, enable "Enable UTF-8 worldwide language support"
Go to Settings and then: All Settings -> Time & Language -> Language -> "Administrative Language Settings"
rahulsharma
Forum|alt.badge.img+12
  • Jan 4, 2021 9:46 PM UTC
Hi @jamal​
jamal
  • Jan 10, 2021 9:20 PM UTC
Thank you rahulsharma. It works fine
Best
Jamal
 Clip_185
Clip_184
