FME 2020: How to remove points duplicates (identical points)?
  • Jan 31, 2021 10:38 PM UTC
  • 9 replies
  • 1444 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how to remove points duplicates.
Clip_337
Clip_336
nielsgerrits
Forum|alt.badge.img+67
One way to do this is to use the Matcher transformer, and use Single Matched and Not Matched outputports.
Another way is Geometry Extractor (fme_geometry) followed by a DuplicateFilter (_geometry).
hkingsbury
Forum|alt.badge.img+73
  • Feb 1, 2021 7:47 PM UTC
PointOnPointOverlayer would also be worth looking at. It has tolerance so could be usefull if your points are not precisely at the same coordinate
jamal
  • Feb 1, 2021 9:24 PM UTC
Thank you guys for the help.
In the screenshots below, the text 16 and 17 are duplicated. I couldn’t figure out why the tools you have already provided fails to remove the duplication
The data is attached
Clip_343
Clip_344
Clip_345
hkingsbury
  • Feb 1, 2021 9:56 PM UTC
Clip_343
Clip_344
Clip_345
The _overlap attribute coming from the PointOnAreaOverlayer identifies that those points have one overlap, you now need to filter out those that overlap
nielsgerrits
Clip_343
Clip_344
Clip_345
Make sure you only checked "Geometry" in the parameters.
jamal
  • Feb 2, 2021 8:18 AM UTC
I couldn’t manage how to catch the duplicated points neither to clean them as per the screenshot below
Clip_29
arnovananrooij
@jamal​  I would try to use a CoordinateRounder :matcher
nielsgerrits
Clip_29
This should be not that hard... You only need the Matcher. Set it only to check geometry. If you only get NotMatched output, the points are not exact duplicates.
2021-02-02_17h21_53
jamal
  • Feb 7, 2021 7:27 PM UTC
Thank you for the help.
The CoordinateRounder, GeometryExtractor, and DuplicateFilter works fine.
The Matcher fails to catch duplicate texts coming from AutoCAD
Clip_362
