FME 2020: How to exclude fields added by the “Deaggregator” tool?
  • Feb 1, 2021 8:01 PM UTC
  • 96 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how to exclude fields added by default as the the “Deaggregator” tool is performed
Clip_341
Best answer by hkingsbury
You can use an AttributeKeeper or AttributeRemover after the Deaggregator. In your position, I wouldn't be worrying too much about them, and tidy all my attributes at the end of the process. There are of course cases where it is crucial to remove attributes mid translation
hkingsbury
Forum|alt.badge.img+73
  • Feb 1, 2021 9:51 PM UTC
Hi @jamal​ ,
As an alternative to removing them at the end of your translation, in the Deaggrator if you remove the values for the 'Part Number Attribute' and 'Geometry Name Attribute' parameters then the fields you've highlighted will not be created.
jamal
  • Feb 7, 2021 7:33 PM UTC
Thank you guys for the help. The AttributeRemover works fine
Clip_363
