Find non UID and nulls, calculate based on last highest UID in data and write to existing gdb.
  • Mar 19, 2023 10:32 PM UTC
  • 63 views
I've looked all afternoon for the answer to this probably simple task. I am working with a feature class in a gdb. The feature class has a unique_id field that may may be populated with duplicate numbers or be null. I need to find all the dup ids or nulls, calculate them incrementally based on the last highest unique id while leaving the other records alone. I was able to put something together that seems to work when if I set the writer to overwrite existing gdb. Is there a way to do all of this and just update the existing gdb? I don't want to loose the other feature classes and tables in the gdb. I'm pretty new to FME!
daveatsafe
Forum|alt.badge.img+24
  • Mar 20, 2023 4:45 PM UTC
Hi @jeaner​,
Use an AttributeCreator to set the attribute fme_db_operation to UPDATE on the features, then follow the steps shown in the following article to use the Geodatabse writer in update mode: https://community.safe.com/s/article/geodatabase-behaviour-updating-a-file-geodatabase
  • Mar 22, 2023 9:16 PM UTC
Hi @jeaner​,
Thank you!
