Filter out (with TestFilter?) records starting with specified word
  • Nov 1, 2022 12:11 PM UTC
  • 8 replies
  • 79 views
scarter
Forum|alt.badge.img+10
Hello Group,
I have a polygon dataset of LSOA boundaries read into FME. It contains a field called ‘LSOA21 2021 name’. The values in that field are entries like 'Southwark e09', 'Lambeth e08' and 'Lewisham e13'.
I want to filter out only those records where the value begins with the word ‘Southwark’.
I’ve added a TestFilter with an If Test Condition of @Value(LSOA21 2021 name) CONTAINS_REGEX Southwark. But that is maintaining the entries where LSOA21 2021 name equals, for example, Lambeth e08.
I’ve been looking through https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/!Transformer_Parameters/StringFunctions.htm, but couldn’t work out exactly what string I need.
Any ideas, please?
Thanks,
nielsgerrits
Forum|alt.badge.img+67
I would use the operator "Begins With" instead?
scarter
  • Nov 1, 2022 1:24 PM UTC
Thanks for that. I change the condition to…. [cid:image001.png@01D8EDF5.318ACCA0] … but I’m still getting results where LSOA21 2021 name equals, for example, Lambeth e08. Thanks,
scarter
  • Nov 1, 2022 1:27 PM UTC
Thanks for that. I changed the condition to…
Annotation 2022-11-01 132619… but I’m still getting results where LSOA21 2021 name equals, for example, Lambeth e08.
Thanks,
geomancer
Forum|alt.badge.img+71
  • Nov 1, 2022 3:30 PM UTC
Southwark-ish
scarter
  • Nov 1, 2022 3:48 PM UTC
Thanks for that. I've changed it to @Value(LSOA21 2021 name) BEGINS_WITH Southwark. Unfortunately I'm still getting records starting with Lambeth etc.
Annotation 2022-11-01 154414
geomancer
  • Nov 1, 2022 3:56 PM UTC
Not quite.... Left Value should only contain the attribute LSOA21 2021 name
The BEGINS_WITH is added in the Operator column.
Begins_With
geomancer
  • Nov 1, 2022 4:05 PM UTC
Which leads to
scarter
  • Nov 1, 2022 4:36 PM UTC
Thank you. That's resolved now.
