FeatureWritter not inserting data with no errors
  • Oct 26, 2022 5:50 AM UTC
  • 280 views
Have a FeatureWriter to insert data into a SQL table. It ran successfully without any error. However, no data shown in the destination database table. Reviewed the log and it says Features not written (see below):
AttributeBelow is the Feature Writer:
FeatureWriter
Both FME Desktop and Server are the same 2021 version. FeatureWriter insert works well in my other workspace. Not sure why it didn't work here.
JennaKAtSafe
Forum|alt.badge.img+9
Hi @fmesafejde​, curious if you might have truncated the table you're writing to. Could you attempt it with the regular MSSQL writer to see if that makes a difference?
  • Oct 27, 2022 7:21 PM UTC
Hi @jennaatsafe​
Upon reviewing log file, turns out one of the SQL table column does not allow nulls.
Added a blank space in Attribute Manger for that field and the inserts works now.
Thanks.
