Feature Reader - Pass on Schema Attribute to the Generic Port
  • Oct 5, 2022 8:57 AM UTC
  • 458 views
robertr
Hello,
I am struggling with what I am sure is a very simple thing but one that I cannot sort out.
I am using Path to search for specific files in a directory which I then read with the Feature Reader. Thing is, I need part of the path_rootname as an attribute to use forward but I cannot seem to be able and extract it. I created "Year" as per the snips but I don't know how to use it forward. I only get the values from the Generic port but for "Year" I get <missing> for each row.
I can see the "Year" attribute in the <Schema> port (and it shows up correctly) but I do not know how to pass it on to the next transformers. I tried connecting the <schema> port along with the <generic> one but it doesn't work.
I also tried attribute exposer, attribute creator but no luck. Any ideas on why this isn't working? thank you!
nielsgerrits
Forum|alt.badge.img+67
At the bottom of the FeatureReader fold out "Attribute and Geometry Handling" and choose "Merge Initiator and Result".
robertr
  • Oct 5, 2022 9:18 AM UTC
thank you, @nielsgerrits​, that did the job.
I am now trying to understand the logic behind. I initially had "Only use result". I have to read what the difference is. Thank you again,
nielsgerrits
From the documentation:
Merge Initiator and Result: Output features will contain all of the un-conflicted attributes from the results of the read as well as any un-conflicted attributes from the Initiator feature. This mode will handle conflicted attributes based on the Conflict Resolution parameter.
Only Use Result: Output features will contain only attributes resulting from the read.
Only Use Initiator: Output features will contain all of the attributes from the Initiator feature, but none of the attributes resulting from the read.
Prefix Initiator: Output features will contain attributes resulting from the read, as well as attributes from the Initiator feature but with the Initiator attribute names prefixed with the Prefix parameter.
