Extract Informtion from Logfiles
  • Oct 27, 2022 12:28 PM UTC
  • 27 views
asadamjad
Participant
Forum|alt.badge.img+12
I need to extract the Values from Logfiles and create an HTML report with separate columns
from this code I need the date and time ... stats (Table Names), inform (Transation Success and duration
I m using fme desktop transformer
FMEServerJobSubmitter
FMEServerLogFileRetriever
2022-10-27 11:52:48|  1.7| 0.0|STATS |Past Track        1
2022-10-27 11:52:48|  1.7| 0.0|STATS |Past Wind Radii                                                             1
2022-10-27 11:52:48|  1.7| 0.0|STATS |Storm Surge Communication Points                                          308
2022-10-27 11:52:48|  1.7| 0.0|STATS |==============================================================================
2022-10-27 11:52:48|  1.7| 0.0|STATS |Total Features Written                                                    878
2022-10-27 11:52:48|  1.7| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2022-10-27 11:52:48|  1.7| 0.0|INFORM|Translation was SUCCESSFUL with 2 warning(s) (878 feature(s) output)
2022-10-27 11:52:48|  1.7| 0.0|INFORM|FME Session Duration: 5.7 seconds. (CPU: 1.4s user, 0.3s system)
asadamjad
Participant
  • Participant
  • Oct 27, 2022 5:20 PM UTC
any one here
itsmatt
Forum|alt.badge.img+48
  • Oct 27, 2022 6:16 PM UTC
If you really want to parse the fme log file you'll probably need to use a text file reader or CSV reader and then filter the lines for what you need​
