Extract image from PDF
  • Apr 2, 2021 9:36 AM UTC
  • 338 views
Hello !
I'm actually trying to extract image (raster) from a PDF, but I'm having a black background. I've tried to extract as vector, but for FME, the pdf is a raster image with text as polygons and area box as line. I need the inside information from the pdf ( see attached image). Unfortunately, I'm not being able to have a proper raster representing the initial image. Should I perform an operation on resulting extracted image, so as to remove the black background. If yes, can someone help me.
Thanks a lot!
nielsgerrits
Forum|alt.badge.img+67
If you share the pdf somebody can try and reproduce.
caracadrian
Forum|alt.badge.img+23
  • Apr 2, 2021 3:21 PM UTC
Use RasterBandNodataSetter to remove what you need.
RasterToPolygonCoercer to go from raster to polygons.
Usually you need to do a lot of cleanup on rasters from pdf because of the compression so good luck.
  • Apr 6, 2021 12:04 PM UTC
Yes, you are right. The problem is from the PDF compression. I've tried to deflate the PDF and I don't have the black background anymore! Thanks for the hints!
