Extract data from Tableau
  • February 20, 2021
  • 29 views
mr_fme
Forum|alt.badge.img+9
How to read a csv file that is inside the Tableaut panel on this website below:
https://www.saopaulo.sp.gov.br/coronavirus/isolamento/
canerakin
  • February 24, 2021
mr_fme
  • February 24, 2021
Ok, but I wanted to download it with FME, there is no specific link for this button
Thank you for sharing this way of extracting data from Tableau. This method could be useful since I need to extract these files directly from Tableau to Jira. I read in this article that the Jira application may be more effective in some situations, so I connected them. It took some time to figure out how to connect these applications properly. Hopefully, I found this article that helped me avoid more mistakes while installing them https://newsupdate.uk/how-to-connect-tableau-to-jira/. Once again, thank you for sharing this guide here. If I get any problems with extracting those cvs files, can I write you in private messages, canerakin?
