Excel Reader: Any way to read the displayed, formatted values for number cells?
  • Apr 30, 2021 9:30 PM UTC
  • 125 views
tfcw
I have an excel sheet, and need to read the value that's displayed in the cell, rather than what the actual saved value is.
1I haven't had much luck being able to find any way to do this. I was hoping the <attribute_name>.formatting attributes would contain this value, but it doesn't seem like it is.
2
This is messy data, and values in this column might be text, might be a number, might be rounded to different decimal places, or might be padded with .0 in case of integers. So any solution would have to be on a per cell basis rather than making any global assumptions on how a number ought to be formatted.
If there's a solution that works in FME Desktop 2017 that would be preferable, but I'm willing to use later versions if necessary.
Best answer by connecter
Hi @tfcw​ ,
I tested it with the new Version 2021. Here is how it looks like:
Excel_readerExcel_reader_2Maybe someone @safe can help here, why it looks so different and how it have to look like.
connecter
Forum|alt.badge.img+10
  • May 3, 2021 10:55 AM UTC
Hi @tfcw​ ,
tfcw
  • May 3, 2021 1:42 PM UTC
Hi @tfcw​ ,
Thank you! I've installed FME 2021 and I'm getting the number_format_string text in the .formatting attributes, I think this is exactly what I need
