Euclidean distance
  • Dec 1, 2020 8:23 AM UTC
  • 5 replies
  • 189 views
I would like to know if there is any processing in FME as "Euclidean Distance" tool in ArcGIS.
Thank you.
Clara.
  • Dec 1, 2020 9:01 AM UTC
If you simply need the euclidean distance between two points, the easiest is maybe to create a line between those two points (2 x VertexCreator) and then something like the GeographicLengthCalculator from the FME Hub.
  • Sep 10, 2021 3:58 AM UTC
Hi david. yes... i am also in dire need of euclidean distance (raster) in FME... GLC is not adequate since I'm am generating a land suitability index based on continuous data...
  • Sep 10, 2021 6:51 AM UTC
I'm not sure I understand the question. For maximum visibility, the best is probably to repost as a separate question. Make sure to include as much detail as possible, including sample data and/or screenshots, if possible.
amdubois
  • Feb 9, 2022 7:54 PM UTC
Hello,
I am also hoping to find an equivalent to Euclidean Distance raster from ArcMap in FME. The idea is to input a shapefile (ex. points representing bus stops) and generated a raster with a specific resolution, where each pixel holds a value representing the distance to the nearest point from this pixel.
imageCheers,
sandervanegmond
Forum|alt.badge.img+9
Hello,
I was looking for the same functionality and managed to do it with the following transformers:
  1. Create points on the Area of Interest using a 2DGridAccumulator. These points will be the base of your raster.
  2. Use a NeighbourFinder with your input data as candidate and your grid points as base.
  3. Use a 3DForcer setting the _distance attribute as z-value
  4. Use a NumericRasterizer to create the final raster
I hope this helps
