Esri polygon shape file to KML conversion, without fill need to generate Polygon features in KML. Please find attached file for my generated output and Expected output samples.
  • Aug 19, 2020 3:06 AM UTC
  • 11 replies
  • 233 views
venu
Forum|alt.badge.img+5
 Expected
Expected output Generated
Generated output
Best answer by takashi
Hi @venu​ , I tried to write a transparent polygon with a KMLStyler (Fill Opacity: 0.00) and KML writer into a KML dataset, and successfully did that.
I'm using FME 2020.1.1 build 20608. What version of FME are you using?​
nielsgerrits
Forum|alt.badge.img+67
Convert the polygon to polyline using the GeometryCoercer (fme_line) before writing it.
Of the polygon has donuts in it, you need the DonutHoleExtractor before the GeometryCoercer.
Forum|alt.badge.img+54
  • Aug 19, 2020 8:43 AM UTC
If you just want to change the display, but still want to be able to click on the polygons to retrieve information, I would use a KMLStyler and set the Fill Opacity to 0
venu
  • Aug 19, 2020 6:56 PM UTC
I don't want to convert as line.. I need polygon without fill​
venu
  • Aug 19, 2020 6:58 PM UTC
I have tried this, but still I didn't get the output as like I want. I hope that is bug in the KMLStyler
venu
  • Aug 19, 2020 7:16 PM UTC
@Takashi Iijima​  please suggest the workaround.
  • Aug 20, 2020 7:59 AM UTC
  • Aug 20, 2020 8:42 AM UTC
The KML styler also works as expected for me in 2019.2.3.1 Build 19823
venu
  • Aug 20, 2020 10:55 AM UTC
Hi @Takashi Iijima​
I am also using same version 32bit FME desktop, but result is coming with Fill
Parameter details below
KMLStyler
Please advice
  • Aug 20, 2020 11:12 AM UTC
Hi @Takashi Iijima​
KMLStyler
Please advice
Set the fill colour (even though you won't see it). If I don't set this I get a white fill
venu
  • Aug 22, 2020 2:45 AM UTC
Hi @Takashi Iijima​
KMLStyler
Please advice
Thanks, I understand works fine​
venu
Works fine thanks​
