Erstellung eines Features mit pythonCreator
  • Dec 13, 2023 3:17 PM UTC
  • 58 views
arash_hokm
Forum|alt.badge.img+8
Hello FME Community,
I get the following error message when creating features in FME using PythonCreator. Does anyone know what the problem is?PythonCreator
geomancer
Forum|alt.badge.img+71
  • Dec 14, 2023 6:39 AM UTC
According to the error message, there is no method input(self, feature) in your Python code.
This method is present when you open a new PythonCreator, so you may have removed it.
import fmeobjects
class FeatureCreator(object):
    """Template Class Interface:
    When using this class, make sure its name is set as the value of the 'Class to Process Features'
    transformer parameter.
    def __init__(self):
        """Base constructor for class members."""
        pass
    def input(self, feature: fmeobjects.FMEFeature):
        """This method is called once by FME to initiate feature creation.
        Any number of features can be created and emitted by the self.pyoutput() method.
        The initial feature argument is a placeholder and can be ignored.
        newFeature = fmeobjects.FMEFeature()
        self.pyoutput(newFeature)
    def close(self):
        """This method is called at the end of the class."""
        pass
hkingsbury
Forum|alt.badge.img+73
  • Dec 17, 2023 6:46 PM UTC
Building on the comment by @geomancer​ , the code in your close function needs to be in the input function
