Error with HTTP Caller when running Workspace from Command Line (Jenkins)
  • Feb 14, 2023 2:30 PM UTC
  • 144 views
I have a pretty basic workbench with a HTTP Caller which processes the downloaded data to insert. When I open the Workbench it works perfectly. I preset all the input parameters so I do not need to pass them into the model.
However when I try and run the workspace from command line, specifically in Jenkins, I use the following command:
"C:\\Program Files\\FME\\fme.exe" "\\\\xxx\\xxxx\\MY_MODEL.fmw"
I get the following error:
HTTPCaller_4_<Rejected>: Termination Message: 'HTTPCaller_4 output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
Program Terminating
Any idea what would cause the http caller to fail only when run from command line?
Any help would be greatly appreciated!
  • Feb 14, 2023 3:36 PM UTC
Try connecting a Logger followed by a Terminator to the Rejected port of the HTTPCaller_4. Please post the logged messages here.
  • Feb 15, 2023 11:26 AM UTC
Hi David. With the logger I was able to resolve the issue. Thanks for your reply and I'm very grateful for your help
