Error when publishing with uploads to FME server
  • Aug 17, 2022 9:26 AM UTC
  • 391 views
mortonprice87
When publishing any workspace to FME server, with files that need to be uploaded, i get the following error.
Publish failed - FME Server encountered an error and reported the following message.
The resource name must not contain any of the following characters: \\ / : * ? " < > | & = ' + % #
non have my files have these characters
Its happening with any new workbence, and it doesn't seem to matter what the reader is.
even simple workbence, with a reader straight to a writer fails to upload.
Wondered if anybody has encountered this.
Using FME Server/desktop 2020.2
geogaard
Forum|alt.badge.img+15
  • Aug 17, 2022 9:35 PM UTC
richardatsafe
Forum|alt.badge.img+11
Hi @mortonprice87​ ,
Would you be able to confirm that the build number of FME Server is greater or equal to the build number of FME Desktop. You can get this error if your desktop is a later build. If that's not the issue, please feel free o make a case and we can help refine the issue.
keithmiller
Participant
  • Participant
  • Mar 18, 2025 7:50 PM UTC
Did you ever find a solution for this problem as we’re having the same issue now on FME Flow 2024.1, build no 24612.
Thanks
matt.m-at-safe
Forum|alt.badge.img+14
Hi ​@keithmiller are you publishing from Workbench 2024.1 to Flow 2024.1? The build of FME Workbench should ideally be the same, but Workbench can be a little behind, as long as it’s the same major version.
You can submit a case with the workspace you’re trying to publish and we can take a look: https://support.safe.com/hc/en-us/p/Support
